RCU Forums - View Single Post - CMP Hellcat
Thread: CMP Hellcat
Old 07-17-2007 | 04:35 PM
  #1794
opjose's Avatar
opjose
Default RE: CMP Hellcat
ORIGINAL: warbird51
Hi Ron,
Putting a valve in the fuel line maybe would fix the fuel gravity feeding into the engine, but it won't help the problem of it leaning out when you go inverted.
I can't believe anybody hasn't run into this before.
I don't run Saito's, though I just received my first that I will be installing, but with all of my unpumped 4 strokers ( Mostly O.S.'s) , as long as the fuel tank mid line is not too far from the carb spray line, the plane doesn't care if it is inverted or not.
I tend to run most of my engines inverted as well, and the only minor problem tends to be with a slightly tighter tuning window, and a tendancy to siphon once the fuel level is high.
