RE: CEN or HPI or Traxxas
I have a Genesis same as the GST except for 3-4 mods. you can make these handle very good with the right shock set up. Mine will wheelie no problem and still give my friends LST w/pico a run for his money. If you want to save some serious money pick up a used Genesis LIMITED the difference between the limited and the GST are:
This is from CEN
The main difference is the brake syste,m (GST uses the nemesis set-up) and the servos and radio are slightly different. Also the motor has been improved with slight porting and timing differences.
Thanks for the great questions,
Customer Service
I picked up a Limited for $220 RTR
