you should have a crankcase pressure fitting somewere on your motor otherwise u will have 2 install one. one end of the in/out on the pump goes to the tank to the carb there should be an arrow showing you the correct path to follow for that deal.
here is perry site in case u need to hear something from them:
http://www.perrypumps.com/
