RE: Composite-ARF Integral, kinda build thread
The elevator was completely nuetral inverted and it tended to climb on inverted 45 degree up lines set at Jason's CG.
Talking with people in my club they are not suprised at the way Jason set his plane up. He is an extremely good Flyer and Probably likes that nuetral feel.
I sanded both edges of the Aileron and Stab. Probably more on the wing then the control surface since that is what goes above the control surface.
I am not sure how quick you like you plane to respond to elevator input, but for me 205mm CG was way to twitchy.
I am in the process of building a carbon fiber push rod set to get those servos out of the Stab.
If I move them forward I can eliminate most of the weight I added to the firewall.
Carl
