RCU Forums - View Single Post - Midwest Sweet Stick Revival (a work in progress)
Old 07-18-2007 | 06:43 PM
sscherin's Avatar
sscherin
Default RE: Midwest Sweet Stick Revival (a work in progress)
OK Tail wheel pics
I know it's kinda long but it's easy to trim down if necessary.
I'll cut it down when I figure out how much throw I need on the elevator.
If I had to make another I'd rotate the pin 45 degrees from the set screw instead of 90.
Then the notch for access to the set screw wouldn't be needed
The brass washer I soldered on for the wheel is a spacer for a dubro ball link.
ID:	725696   Click image for larger version
ID:	725697   Click image for larger version
ID:	725698   Click image for larger version
ID:	725699   Click image for larger version
