RCU Forums - View Single Post - engin trouble need help?
Old 03-10-2003 | 05:19 PM
buyrbware
Default engin trouble need help?
open your carb look at the needle if the low end is closed it won't allow fuel to enter! back it off till you hear a hiss while blowing through the fuel tube then you know your getting fuel! It is a air fuel mixture Air coming thru the carb throat and fuel comming thru the needle..needle closed shut and you get no mixture!
