RCU Forums - View Single Post - engin trouble need help?
Old 03-10-2003 | 05:35 PM
buyrbware
Default engin trouble need help?
As the barrel rotates back and the throttle come open the lowend needle will back off its seat...And fuel will enter at that point ...If that needle is closed to far, you would have to open your throttle past half throttle while starting the car to get the neddle to back off the seat.....
Why not just adjust it the correct amount before going through the hassle of trying to figure out how far to open the throttle to get it fuel to flow so it will start......
I don't think this guy is worried how you start your rig kyokai2, I would think he wants to know how to set his up so it will start effectively everytime! The method i have described is in the o.s manual and is comon sense on how carburators work!
If this is good for you then great, but why make it difficult for him..Carburation is not rocket science, so do the easy setup method discribed and your car will start....
Thanks Tom
