RCU Forums - View Single Post - Muggy Help
Thread: Muggy Help
Old 07-20-2007 | 09:08 AM
traxxasracer_4
Default RE: Muggy Help
ORIGINAL: DiscoStu666
Hi
I recently bought myself a Team Losi Muggy..........I wouldlike to go racing, but I am having a problem with the car and its settings, I have replaced the engine with a Picco .28 P3, the engine is awesome, but the Muggy's front end is refusing to give grip, I have softened the front end, the rear I have but some heavier oil in to trynot allow the front to come up so easy. Can anyone else suggest what I can do to stop the front end balloning like mad and give me some handling?? ? It is uncontrollable when on power....Anyone got any suggestions??
I might mention that it is running its standard wheels and tyres....
Stu
first you know this should be in the monster forum right ? no harm done i'll try to help you out. if you put heavier diff fluid in the front it will not allow the wheels to unload like they are doing now and should help with the traction. also use 60 wt shock oil all around so you arent biased to the front or back i have found that the same oil in all the shocks works better than different oils in the front and back.
