RE: Gosh Darn it! Please help.
cut the old stripe from the covering if possible then tape it to the black you are planning on using and use it as the pattern to either trace or cut around.if you are using ultrakote you need to apply it with a solvent and not use heat as the shrinkage will cause distortion along a straight line
