RCU Forums - View Single Post - getting planes from knife edge?
Old 07-21-2007 | 07:12 PM
bigtim
My Feedback: (13)
Default RE: getting planes from knife edge?
there is a tutorial that will tell you how but this is the quick and dirty way.
go to the swap pages select aircraft there you will find the aircraft section as well as color schemes.
click the aircraft you wish to down load and click the address for the plane.
A box will come up there will be 2 slots the bottom one will say G3x click it and select "all files" and save to your desktop so you can find it easyer.
close knifeedge window and open your G3.5sim.
click on "simulation"on the upper far left side and go down to "import" and click G3x there should be a pop up window with a list of your desktop programs click the plane you down loaded from KE on the desktop and there should be a prompt at the bottom of the screen saying the "import was succesfull"
then go to "aircraft" select custom and there your plane will be.
there will be a DDS prompt and the picture of your selection should appear.
I am pretty sure those are all the steps I do,I tryed to recall from memory but check the KE site just to make sure it's a sticky at the top of the swap pages.BT
