RCU Forums - View Single Post - Engine Mounting
Old 07-21-2007 | 08:57 PM
fjaust
Default Engine Mounting
I have a 45cc gas engine to install on my Edge540. On the engine box of the plane there are vertical and horizontal lines marked, offset from centre but that's all I have to go on. There was no mounting template included in the instruction booklet or with the engine.
What's the best way to get the engine installed and in the correct position using those lines already marked on the engine box?
Also, with the lines offset from centre does that mean I still have to use washers under one side of the engine when mounting it to get correct thrust or is that why you set the engine up slightly off centre?
Thanks, FJ
