RCU Forums - View Single Post - Rigger for first timer ( to riggers )??
Old 07-22-2007 | 02:21 AM
  #67
Simon.O.
Default RE: Rigger for first timer ( to riggers )??
This is becoming a bit like a blog isn’t it ?
Well her is todays progress.
I was initially suspecting a dodgy charge, but that was not the case. It turned out to be a loose wire to the motor. I resoldered it and tested it in the paddling pool. It was still bad..
I am now suspecting that the 15+year old motor could be on its last legs.
I have fitted the stock 540 can off the air powered boat as a trial unit.
I will run again in the morning and bring the results back tomorrow night.
If you think this is too boring with me updating day to day then say so. Otherwise I will continue to do so until I get this rigger running well.
Cheers guys.
