Re: Pete & Poke
Chief:
This is a really fun kit and makes a great flyer. Pay attention to the instructions. Follow them and you won't get into trouble. The cabane struts are a bit tricky as far as getting the wing incidence right, but don't sweat it too much. You can always use a shim on the wing mount to get the incidence right. An incidence meter helps a lot here. Invest in one, especially if this isn't the last kit you'll build.
One other suggestion I have is to build the Landing Gear fairings out of plywood to make them a bit stiffer.
Have fun and post a picture when you're done!
papermache
