RE: glitches
The engine was not running on the test. I was just cheking to see if the clitches in the Tx and Rx. Both Tx and all 3 Rx did the same thing.. all ov them started to glich about 20 paces. Now that I see that, that is ok now I will start working on the glitch with that gas enging...
I will look at all the things you all was talking about. The one thing is.. if the book said I need 20 to 30 paces.. but with gas you should get about 80% of what you got with the enging off.. Wich is about 15 paces.. I jus do not like that for some reson..
Paul
