RE: Eagle 2 wing warp
rubber band the wing on the fuse. the twist you give it will either push the nose down, or it will push the tail down. If the nose is being pushed down then all is good, I don't think you can push it through the table. If the tail goes down allow it to rest on the table and then give the required amount of twist with one hand and the heat gun in the other.
