RCU Forums - View Single Post - avistar tail dragger?
Old 07-23-2007 | 02:01 PM
Wild Foamy's Avatar
Wild Foamy
Default RE: avistar tail dragger?
ive done a conversion to my yamamoto in about 15 minutes (excluding epoxy drying time)
i basically took off the nose wheel, cut the ply landing gear block out of the bottom of the fuse, cut another section out of the fuse infront of the gear, moved the gear forward to the new slot and glued it with 30 minute epoxy, then glued the other section of the fuse where the original landing gear was
pics to come if i can find me cam
