Pacer Hinge Glue...
I tried Pacer Hinge glue for the first time and its the easiest hinge install I have ever had. Theres no mixing and in 1/2 hour the hinge is in there solid. The stuff looks like wood glue but it isn't. I tried pulling a hinge out one of the hinges after about 30 seconds to reposition it and it had all ready started to set in place. The stuff works really well. It sure beats epoxy for gluing in hinges and all it takes is a little water and a light rub gets the left over glue off the covering after it has dried. If you haven't tried it and have hinges to install, consider using this stuff! [8D]
