ORIGINAL: bodywerks
I accompany every correction with a blip of throttle - I have MUCH better control that way. Also, when the belly is facing you, fly the tail. That way, you will naturally input the correct control direction. Every failed attempt I see is the result of falling out of the hover due to the wrong inputs as soon as the belly faces them. After a while, the correct inputs become a natural reaction.
yep
