RCU Forums - View Single Post - Need some help /W control settings
Old 03-10-2003 | 11:53 PM
Whirley Bird
Default Need some help /W control settings
Originally posted by FLYBOY
Does it have one servo or two? If it is two, is your electronic mixing set to control the second servo?
One other thing, take the controll rods off the ailerons and make sure the hinges are loose on both. you may have gotten glue on one side and locked the hinges. Just a though.
Hope one of those helps. Let me know what system you are using if one of those don't. (2 servos or one)
This seems to be the problem.
Seems like one is not right or was not installed right.
This is an RTF.
Only 1 servo and no binding.
I can get what I want if I push the short rod with my finger but the servo is not strong enough to push that hard.
Maybe toss out a few $$$ for a stronger servo?
Everything else is 100% A-OK and the covering is BEAUTIFUL!
I don't want to tear that wing apart so maybe stick with the 3/8th?
I don't think thats enough for the Avistar with a 46 LX engine on it
