RCU Forums - View Single Post - Gas Engine? Giles 202 140
Old 07-23-2007 | 09:56 PM
nitro wing
Default RE: Gas Engine?
Do search,quite a few people have strapped on the 26 and bigger,I believe that the outcome was that the plane was not powered enough and starts getting heavy.The Giles is a real good flier,but one must keep all excess weight off,or it becomes a pattern missile.It depends on your style.If you like a quick pattern type,it may work,but dont expect this one to float around or 3D well.Overall it flies great with an engine that balances.I had an OS 160 on mine,lots of excess brute power(under 12 pounds),but in my opinion was a bit heavy for CG and wingloading.There are a few that did the 26cc gas that will be able to tell the exact expectations from this set up.
