RCU Forums - View Single Post - HELP!!!! Showtime 50 and Engine Muffler
Old 07-24-2007 | 10:54 PM
waross
Default HELP!!!! Showtime 50 and Engine Muffler
I bought a Showtime 50 last weekend and started putting it together. I have an O.S. 46 AX to put in the plane. Don't start the same old rhetoric on you need a bigger engine. The 46 Ax is plenty for this plane. The problem is mounting the muffler. The plane was obviously built around an evolutino engine. When I got the engine mounted the muffler doesn't clear the cut out on the fuse. I loosened the back half of the muffler to see how far I am from getting the muffler in there. This is where I need ideas. Muffler extention , different muffler or make a few cuts to the fuse???
What to do what to do? Here are a couple pix of the situation.........
ID:	729647   Click image for larger version
ID:	729648   Click image for larger version
ID:	729649   Click image for larger version
