ikarus flight sim problem
03/13/03
santi,
the interface cable must be plugged into the com port on the back of your computer. usually there are two (2) com ports. since your modem uses a com port also, you guess which port to plug into. then start your program. if ikarus doesnot find a com port move the connector to the other com port connection. the program will not run without the interface.
it is a great sim
flashingred
