Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
problems with the interface cable on AFP >
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 03-11-2003 | 02:16 AM
santi's Avatar
My Feedback: (32)
Default problems with the interface cable on AFP
i just received my Ikirus AFP today and got it installed onto my PC. When trying to play the Darn thing. There comes a message on the screen that says"Cant find the interface cable" Im able to get the program started but i wont let me continue on. Am i missing something? Has anybody else experienced this problem?
Where can i go or call to get this problem resolved If it cant be solved? Thanks a bunch...
Santi
Old 03-13-2003 | 03:05 PM
I had same problem new dell pent 4 plus fatal error reports sent it back they returned money all i lost was shipping to fl good luck jimmym
Old 03-13-2003 | 04:08 PM
I believe the cable supplied with your Sim must be plugged in to your computer - are you doing this?
Old 03-14-2003 | 01:40 AM
Default ikarus flight sim problem
03/13/03
santi,
the interface cable must be plugged into the com port on the back of your computer. usually there are two (2) com ports. since your modem uses a com port also, you guess which port to plug into. then start your program. if ikarus doesnot find a com port move the connector to the other com port connection. the program will not run without the interface.
it is a great sim
flashingred
Old 03-14-2003 | 01:54 AM
santi's Avatar
My Feedback: (32)
i got it!! This is great. There is a cable interface that needs to pluged in to the port in the back even though you dont use it. I have the game commander pluged in the joystick connector and my 4 channel futaba connected to the com port. Thanks all who replied. This is i think the best sim out there. hovers and torkrolls is almost like the real thing.
Santi
