RCU Forums - View Single Post - quick question
Old 07-25-2007 | 04:14 PM
da Rock
Default RE: quick question
CA hinges will return the surface to neutral when you let go.
If you can move them as much as the manual suggests for throws, and there is no real increase in resistance during the movement, then it just might be the normal CA hinge resistance.
If the resistance seems to build appreciably, the precut hinge locations may not be in line. How wide is your hinge line gap?
