RCU Forums - View Single Post - OS46FX engine and misc stuff
Old 07-26-2007 | 09:40 AM
bruce88123
Default RE: OS46FX engine and misc stuff
ORIGINAL: 747
Yes gentlemen, the needle is off. I just finished making steel mounts. Just that I dont know how bent the black spring should be. Can I leave it the way it is in the Pic? since it looks like its in right angles to the needle axis-looks pretty tight!
Can I use drug store CVS isopropyl alcohol (98% I think )to clean engines? If so can I clean the holes etc and how to reach the holes?
What is fuel proofing dope?
When attaching fuel tubes to lines, do you snug them tight or use epoxy/ca to hold em?
The black spring is bent too far.
You'd be better off using denatured alcohol from Home Depot or another similar source. Isopropyl has a LOT of water in it which will promote rusting. Either way it should be thoroughly dried and lubed after. After-run oil or Air-tool oil would be good.
Any dope would be fuel proofing dope.
Just seat the fuel lines in place and use the correct sizes of line and tubing. No glues/sealers needed.
