RCU Forums - View Single Post - OS46FX engine and misc stuff
Old 07-26-2007 | 09:41 AM
Bax
Default RE: OS46FX engine and misc stuff
You want the ratchet spring to apply just enough pressure to the needle valve to keep it from rotating. If it's bent slightly towards the center of the needle holder, and you have to push it out of the way when you install the needle, it should be OK.
