RE: Landing
lot a good advice here... check out AMA's web site and look in the "primary flight" area where there are lesson on how and WHY to teach landing techniques. it is quite enlightening. remember with a trainer on approach throttle contols altitude and elvator controls speed.
bouncing could be because the plane is sinking to fast ( add the blips of throttle ) or you have let the nose down and built up to much speed (keep the fuse flat and back off throttle to allow it to sink...... it is fun to BLIP the throttle it sounds a lot like an old radial engine plane landing.
your are on the edge of some real fun cause when this skill is learned you will be able to do sweet and slow touch and goes!
HAVE FUN[8D]
