RCU Forums - View Single Post - incedence
Thread: incedence
Old 03-11-2003 | 11:23 PM
David Cutler's Avatar
David Cutler
Default Re: incedence
Originally posted by kegelt
Maybe a stupid ?. I just got a Global Ultimate Bipe. I dont know how many bipes i will own so i dont really want to buy a meter. Is there anyway so check and set incidence, without purchasing a meter? or should i just quite thinking there is and buy a meter? thanks for all the info. Tom
I had exactly the same problem when I built one recently.
I sort-of solved it by drawing a line on the end the tips of each wing with a pencil, exactly along the centre-line of the section (quite easy to do by eye), and then taking a large piece of paper, and drawing two parallel lines, the same distance the wings are apart, and using that as a gauge on the tips of the wings.
You should find the bottom wing is correct already (if it's seated properly on the fuselage sides) and the top adjustable wing can be set against it.
Put it this way, mine flies great after that mickey mouse alignment!
David C.
