incedence
WI
Maybe a stupid ?. I just got a Global Ultimate Bipe. I dont know how many bipes i will own so i dont really want to buy a meter. Is there anyway so check and set incidence, without purchasing a meter? or should i just quite thinking there is and buy a meter? thanks for all the info. Tom
Originally posted by JohnBuckner
John
John
I have one coming along with a CG balancer even though my home made one seems good enough.
The ACCU-THROW is going to get a lot of use here.
The prop balncer???????????
Well I had one and it worked but one day I decided to make an adapter and spin my prop on my dremel tool.At 15,000 rpm I could feel the harmonic vibrations while holding the tool in my hand so now thats how I check my props now.
First the balance then the hi- speed test
FL
You can check by measuring the center of the LE and the center of the TE from a flat surface. It is as accurate as anything, but whatever you measure with has to be perfectly square to the surface you measure from.
The incidence meter is almost fool proof and I think you should go ahead and get one. It will save you a lot of time and give you peace of mind through your projects.
CA
I sort-of solved it by drawing a line on the end the tips of each wing with a pencil, exactly along the centre-line of the section (quite easy to do by eye), and then taking a large piece of paper, and drawing two parallel lines, the same distance the wings are apart, and using that as a gauge on the tips of the wings.
You should find the bottom wing is correct already (if it's seated properly on the fuselage sides) and the top adjustable wing can be set against it.
Put it this way, mine flies great after that mickey mouse alignment!
David C.
