RE: material to seal control surface gaps
Well if thats the case I stand corrected. Thank you for the lesson. In my mind I thought the air traveling through the gap at high rate would cause turbulance around the control surface ...eventually leading to the possibility of loosening the tightness of the hinge etc. Is this not a possibility?
