RCU Forums - View Single Post - Firestorm Question
Old 07-28-2007 | 09:12 AM
FastNeasy
Default RE: Firestorm Question
ORIGINAL: cdm121880
Great choice! Remember, as with any rtr it is a good idea to check all screws, and some people even loctite them (though I did not do this). Be patient during the break-in and do as the manual says. The settings will be nasty rich, so it will be spitting raw fuel at you, and sometimes tough to start, this is normal. After the idle tank it will be very sluggish once you put it on the ground, it may even die a few times, this is also normal. Do it correctly and you will be rewarded with a crisp engine that has a smooth powerband, starts after just a couple pulls (providing it is primed properly), and will last a long time. Have fun!
Thanks for that, How would i use loctite then?
And yeah im a patient guy [8D]
Would the heat cycle method be best for break in ?
