RCU Forums - View Single Post - Maintencance on a Firestorm..
Old 07-28-2007 | 11:04 AM
Snaut Rocket's Avatar
Snaut Rocket
Default RE: Maintencance on a Firestorm..
Dirt hags II work great in the grass. I ues superglue for gluing my tires on never had a problem. I use hobbico after run oil but I heard W-d 40 works just as good. But make sure you put it in the cylinder head and not the carb. make sure you always carry around a small screw driver so you can you adjust the HSN or the LSN.
