RE: Engine fuel leak
If you change the head shims or the total thickness of the head shims you change the compression ratio! So if you only run one shim unless it is the thickness of the three combined you are changing the compression. You might not have a problem running just one but you all so take a chance on frying your engine if you do not know what to watch out four.
