RCU Forums - View Single Post - Engine fuel leak
Old 07-29-2007 | 05:40 PM
neilt6
Default RE: Engine fuel leak
Yup, aim it right at the glow plug from about 1" away, straight down. And are you sure it's not your glowplug that's leaking? Make sure the little brass ring is still on it and it's tight, seems to me if you boosted your compression with a loose glowplug it would leak pretty badly. You might even try replacing it all together, perhaps it's broken somewhere.
