RCU Forums - View Single Post - Engine fuel leak
Old 07-29-2007 | 10:17 PM
46u's Avatar
46u
Default RE: Engine fuel leak
ORIGINAL: neilt6
He said he had 3 brass shims originally, and since the aluminum shim he bought was as thick as two brass shims, he used it and one brass shim to get back to the original height, therefore providing he's got his facts straight, he's not changing his compression.
Brass Shim
Aluminum Shim
3 Brass Shims
1 Brass Shim + 1 Aluminum Shim
So from what he said this is not correct!!!!!!!!!!!![X(] What temp gun did you get? 113F is way cold and I find this hard to believe after running a half a tank. Is the engine still leaking around the head shims? Yes defiantly check the glow plug seal
