RCU Forums - View Single Post - Kadet Lt-40 Engine & Push Rod
Old 02-24-2002 | 09:20 PM
Mrsamman
Default Kadet Lt-40 Engine & Push Rod
Were building the Lt-40 and are going to put an OS 40 fp on it. will this motor be big enough to handle wind and easy loops and rolls? Also I have read that the push rods will flex. Is this when its flying the drag on the control surfaces will cause the plastic tube to bend when the servos try and push them? I didn't look inside the plane that carefully but isn't the tubes glued to the bulk heads every 2 or 3 inches. Is this not sufficient? We demolished our Easy Flyer last weekend so this weekend were building this. Thanks for any input.
Scott
