RE: Two motors...one esc?
Ernest, boat is about 52 inches, and nearest as I can calculate, should weight in at about 12lbs, with everything installed. I figure I'll add one of Graupners larger jet drives without the reverse buckets added for pure thrust if I need to. This third jet will be an on/off switched motor that'll run at full throttle settings only, when max cruising speed is needed. It'll of course have a larger outlet, just as the real vessel used.
