RCU Forums - View Single Post - Question about removing the primer bulb
Old 07-30-2007 | 10:59 PM
w8ye's Avatar
w8ye
My Feedback: (16)
Default RE: Question about removing the primer bulb
If the bulb is the type mounted directly on the carburetor you will have to find a similar carb without a priming bulb and trade the parts. If you just take the bulb off-the carb will suck air and the engine will not run.
Also you probably should plug the return line if it is still on the carb or it will suck air there as well.
