Question about removing the primer bulb
FL
Hello all,
I'm in process of converting a Glow 1.20 engine to gas. I'm using Walbro WT-644 carb. The problem I have is the Primer bulb is on the way of driver washer.
Is it possible to remove the primer bulb from the carburetor without effacting it?
thanks
Borna
thanks
Borna
My Feedback: (16)
If the bulb is the type mounted directly on the carburetor you will have to find a similar carb without a priming bulb and trade the parts. If you just take the bulb off-the carb will suck air and the engine will not run.
Also you probably should plug the return line if it is still on the carb or it will suck air there as well.
