Originally posted by mobil_racer
hello there dear friends
I have my first plane and the the radio has throttle & rudder on the left & ailerons & elevator is on the right, if i was getting g2 simulator what mode would that be?
thanks for your help
Hi there, and welcome to a great hobby!
The mode you describe is mode 2, and the G2 simulator defaults to that (at least, it does in the States).
You can, in fact, change this in the program, as you can assign different channels to different stick movements, but it isn't necessary to do so.
By the way, the simulator is, in my opinion, a really great way to learn the reflex actions needed to fly a model aircraft, and, even though it's a fairly expensive program, it can save you a fortune in broken planes!
Good luck!
David C.
