what mode to buy???
hello there dear friends
I have my first plane and the the radio has throttle & rudder on the left & ailerons & elevator is on the right, if i was getting g2 simulator what mode would that be?
thanks for your help
CA
The mode you describe is mode 2, and the G2 simulator defaults to that (at least, it does in the States).
You can, in fact, change this in the program, as you can assign different channels to different stick movements, but it isn't necessary to do so.
By the way, the simulator is, in my opinion, a really great way to learn the reflex actions needed to fly a model aircraft, and, even though it's a fairly expensive program, it can save you a fortune in broken planes!
Good luck!
David C.
thanks for your help David
i have ordered g2, it is expensive but it will be better to crash on the computer than for real, should be fun
oh yeah the cost over here around shops is $495....ouch
but the plane cost me $700 & i'm getting into r/c planes is should be a good investment
thanks again
Daren
thanks again
Daren
