RE: HELP ME PLEEEEASE
it's So hard to explain this over the internet, id have to show you.
don't use revo mix if you have a HH gyro
it's pointless to tell you the settings of a 6102...i used to have a 6102 traded it for a DX7 which is exactly the same menus with more resolution LCD and improved
Normal Thr 0-65-80-80-80 (AFTER programming ESC)
Idle1/2 Thr 100-100-100-100-100
Normal & Hold Pitch 40-inh-50-inh-100
Idle1/2 Pitch 0-inh-50-inh-100 (-11* to +11*)
travel adjust - default, ch5(gyro gain) 50/50
ECCPM - 50-50-50 (servo horn outtermost hole, approx 8* cyclic pitch) dont do this if youre new. the trex has a roll and flip rate that makes the CPpro feel less squirrelly
d/r & expo all default
reverse, pretty much ch2/3/6 might be reversed to make the swashplate move the right way depending on what servo you plugged into CH2/6
subtrims: Ch2/3/6 added before ANY linkages are sized. according to swashplate level and height tool.
as you can see, the settings are mostly default because i BUILT the heli and linkages around these settings Not according to the instructions. from the servos, to the swashplate, to the microlinks, to the macrolink adjustment
