RCU Forums - View Single Post - 9.6v vs 7.2v
Thread: 9.6v vs 7.2v
Old 07-31-2007 | 03:08 PM
StoneColdFreak's Avatar
StoneColdFreak
Default 9.6v vs 7.2v
Is there any reason to believe that the electronics will suffer if I use a 7.2v in place of the 9.6v that camewith my Matorro Sturmtiger? The voltage is lower, after all. My plan is to remove the triple plugs from the tank and replace them with Deans', which has simply a positive and negative. By the way, if red is positive and black is negative then what is the blue wire...ground? Can I solder it with either the red or black or should I just omit all together?
I haven't even tested the tank because I think I am going to install a Tamiya Tiger DMD and MFU eventually. First, I think that I will make a few modifications, some paint and bit of weathering. I will replace the handles with wire, pin the tow rings so they don't come off, damage the skirts, open the hatches, remove the BB shooter and loader etc.
Thanks!
Chad
ID:	733112   Click image for larger version
