RE: 9.6v vs 7.2v
[&o]Unfortionatly you can't do that the 3 wire plug is another voltage tap into the cells so the tank gets a certain voltage to run some stuff and the full 9.6 to run other things....
you would have to some how make taps into the 7.2 volt packs cells at the acording voltage that the tap is on the 9.6v pack.
