RCU Forums - View Single Post - Tiger 60 Build Thread
Old 07-31-2007 | 08:22 PM
  #112
RCurtis
Default RE: Tiger 60 Build Thread
Glad to hear your's went well! I finally finished the repair of my firewall (thanks to krossk sending me a scan of the firewall outline). Mine ended up at 9 lbs. 10 ounces. Since I am running the same engine you are (OS .91 FX) I was *very* pleased since I was afraid that I was way too heavy. Those box specs really had me nervous. I *know* they were for the standard kit....but I just didn't think that 10 lbs. would be the target range.
I'm still just a *bit* concerned about my CG... It is right at the 3-3/4" mark. Right on the line as far as what the specs say...but we've already proven the specs wrong on one point! Should I be concerned? Michel...where did you end up putting your receiver and battery? When I tried to maiden flight mine the first time, it was already "light" on the nose wheel...if I move the CG back any further I'm afraid I will not have any ground control!
