RCU Forums - View Single Post - Schulze charger question
Old 08-01-2007 | 07:37 AM
Bob_B's Avatar
Bob_B
Default RE: Schulze charger question
Mike,
There is a seperate mode for Nicads and NiMh, The delta peak settings and termination voltage are a little different in each mode.
It will not hurt to charge both type in the Nicad mode. However by simply holding down both button and then releasing the left one first you will enter the program mode. Pressing the "+" button scrolls through the selections and pressing the "-" button sets the selection.
It really does become second nature after using one.
Bob
ORIGINAL: IFLYBVM2
Hi Guys-
I have been using one of the older Graupner Ultra Duo II chargers for years for my nicads. Have recently acquired a Schulze 6-330d so that I can use both chargers together to enable me to charge ECU and radio nicads all at one time.
Two questions-
1. Are the two chargers pretty much the same, other than the fact that the 6-330d will do lipos ? (I don't currently own any lipos)
2. I always use the fully automatic mode-(plug it up and let it go)-If I need to charge NiMH instead of nicads, do I have to change any settings on the charger, or does it 'know' that I am using NiMh instead of Nicads, or does it matter ?
Thanks-Mike Oberst
