RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 08-01-2007 | 05:22 PM
  #332
vander Vecht
Default RE: Composite-ARF Integral, kinda build thread
@Malcolm H: I did not measure the static current or rpm. As the prop is clearly stalled, when run at full power static, the numbers are problably insignificant.
The power is more than enough and the consumption is about 4000 mAh fot a full P 07 program flown in a stiff wind.
The backside of the motor has a wide stance triangular mounting plate that bolts to the nose.
@JPZ: Feel free to use the vid for your website.
Here is a flight video of the Integral: http://airtoimedia.nl/web/upload/vdV...gral%20P07.wmv
