RE: I need a manual for this plane and cannot find one.. help plz
The instruction sheet is of no help here.
You can place a small piece of hard balsa at the servo screw points to raise the servo if you wish.
Typically however when something like this happens I just use a piece of plastic tubing to enclose the pull-pull wire at the point where it will otherwise rub.
