Landing was perfect, so I refueled, recharged and began flight two with the intent of extending the flight envelope a little farther outbound and depth away. I took off, turned outbound and then downwind climbing with the turbine at full throttle, allowing it to pick up some speed. I let it proceed a little further downwind this time before beginning the base turn to upwind. At the point I wanted to make my base turn to upwind I felt no response to input. Then the landing gear extended, which was my indication that the receiver was in failsafe. It continued for what seemed like an eternity, and then I saw the gear retract again. I immediately put the plane into a hard bank to the left to bring it back towards the field. Just as the nose came around to approximately pointing at me, still in a bank, the gear extended again, FAILSAFE. This time the nose tucked straight down, with the belly towards me I could see the gear still extended. At about 30'-50' above ground the gear again retracted, but it was too late. The plane impacted, turbine running at idle, and a full fuel load. EVERYTHING BURNED!!!! The XPS receiver ejected from the plane on impact and appears to have no damage. Everything else, TOTAL LOSS!!
Question, Why did the turbine continue to run after two failsafe occurrences?
