RCU Forums - View Single Post - New to 4D, TX question
Old 08-03-2007 | 10:02 PM
GordonFreeman's Avatar
GordonFreeman
Default RE: New to 4D, TX question
Yup, that is the radio I use. I've got an E-flight Extra260 with thier recommended set-up. The main thing to remember is to make sure you select Helicopter mode on your TX. Which is hard to find (remember), it is found in one of the two main menus....Parameter - Type - H1.
I have P-MIX1:
P-MIX1 >ON
MAS>CH1 (throttle)
SLV>CH5 (pitch)
SW>--
RT>+100
__>+100
I have switch G to do three different curves, I'm not sure if you can change the switch or where it is selected, but at the very bottom of the throttle curve menu (next page) you need to "Un-Inhibit" both IDL1 and IDL2.
You need to be in the right "Menu" for changing all three throttle curves. It is the same menu that you get to P-MIX1. You press the Mode/Page button to toggle from "Menu1" to "Menu2". I forget...the manual probably explains it better.
Normal (for normal flying)
Throttle P5>100%, P4>75%, P3>50%, P2>25%, P1>0%
Pitch 90% all
Idle1 (same as Idle2, but throttle is toned back for bench work)
Throttle P5>30%,P4>25%,P3>15%,P4>25%,P1>30%
Pitch P5>90%, P4>80%,P3>50%,P2>20%,P1>10%
Idle2 (full VPP mode)
Throttle P5>100%,P4>80%,P3>20%,P4>80%,P1>100 %
Pitch P5>90%, P4>80%,P3>50%,P2>20%,P1>10% (same as Idle1)
